Hi.
I want to constrain a chain link to a chain (simplified), and allow it to be simulated in any point.
To do that, I need the green part to follow the yellow part all arround it.
How can I do it?
Solved by Cadmanto. Go to Solution.
See if this thread helps you.
https://forums.autodesk.com/t5/inventor-forum/make-an-assembly-part-follow-a-path/td-p/5569946
Windows 10 x64 -16GB Ram
Intel i7-6700 @ 3.41ghz
nVidia GTS 250 - 1 GB
Inventor Pro 2021
