Inventor Forum
Cut a thread half
3 REPLIES 3
534 Views, 3 Replies
Cut a thread half
Hi! The attached picture itself describes the problem well. I've created threaded coils by means of Thread Modeller (AI'2015). For some reason I want to subtract a rectangle across the coils by extrusion. The coils always remain intact. Would you let me know how to deal with this issue? Thank you.
3 REPLIES 3
JDMather
Notice that you have 3 Solid Bodies.
Use the Combine command to combine the 3 bodies into one before you do the Extrude - Cut.
Did you check the thread-form profile and make sure it is appropriate (60° and not Whitworth 50°)?
Can you attach your ipt file here?
in reply to: JDMather
Yes, it works. Thanks a lot for helping me.
BTW, I've donloaded the model from this very forum.
Regards!
JDMather
Edit the sketch and note the threadform angle of 55°.
This is a British Whitworth threadform - generally obsolete in this century.
Inch or metric standards that I am aware of use a 60° angle.
