Inventor Forum
Creating tiles with sketch defined by borders
8 REPLIES 8
Message 1 of 9
vkulikajevas
700 Views, 8 Replies
I need to tile a surface, that has a complex geometry and area is very big. Squares (tiles) should appear in a drawing only on the face of modeled body. I don't make solids and pattern them, because it has a huge demand on performance and model becomes very slow. Is there a way to define the sketch pattern (in this case I made a block) by another sketch borders?
Note: in the picture Fig A has a texture put on, I need same result in Fig B by sketch elements. I don't use textures for my drawings because, I need lines to appear crisp and visible on a white surface of the drawing.
Tags (3)
8 REPLIES 8
Message 2 of 9
JDMather
in reply to: vkulikajevas
@vkulikajevas wrote:
... I don't make solids and pattern them, because it has a huge demand on performance and model becomes very slow. .
Can you use Split Face rather than pattern solid?
Can you do it the hard way, huge demand and poor performance - and attach that file(s) here?
Otherwise, I would use AutoCAD for 2D.
Message 3 of 9
vkulikajevas
in reply to: JDMather
Split Face is bad, because I have to select each and every square. Split command can create only one closed surface at a time. So this command is not an option. This file I created is only for reference and has no issue in multibody creation. I have much bigger one, that has that problem.
The question still stands, if it is possible to create sketch bounded by another sketch on a surface of a plane or a body face?
(P.S. it is Autodesk Inventor question. Autocad is different. I have no problem in making tiles on Autocad myself :))
Message 4 of 9
Message 5 of 9
JDMather
Not the way I do it. I can do many many at one time.
That is why I suggested you attach your file here (done the hard way) so that an easier technique can be demonstrated.
Otherwise, I would do it in AutoCAD.
Message 6 of 9
Actually doing it in one part is not slow either.
Message 7 of 9
vkulikajevas
Please show me :). Attaching the file.
Message 8 of 9
johnsonshiue
Hi! Is this what you are looking for? See attached part.
Many thanks!
Software Test Engineer
Message 9 of 9
vkulikajevas
in reply to: johnsonshiue
Many thanks! Exactly for that I was looking for!
Technology Administrators
