Flat pattern creation error
Message 1 of 11
Hello
I have problem with creating a flat pattern of one part. It is quite simple part, can't figure why the flat pattern creation fails.
I'm using Inventor 2016.
Error:
Sheet1.ipt: Errors occurred during update
Sheet1.ipt (Flat Pattern): Errors occurred during update
Definition1: Could not build this FlatPattern
Could not split between bend and plate. Please check if there is a relief gap so the bend can be deformed.
Replies (10)
Message 2 of 11
-niels-
Welcome to the forum!
Cut1 does not cut across bend, which results in the following:
Either make sure the cut does not cross the bend or use "cut across bend" and then correct the other features to your design intent.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 11
Thank you for such a quick reply!
It was that cut which caused the error.
Message 4 of 11
I make a lot of sheet metal parts and normally don't have a problem creating flat patterns. However, I have a part that refuses to make a flat pattern, and the error message says "Could not split between bend and plate."  I suspect the problem is similar to the one addressed in this forum, but I don't understand the instruction you have provided.
I can attach the part if that would be helpful.
Steve
Message 5 of 11
JDMather
Steve
Yes, that would be helpful.
Message 6 of 11
Here's the Inventor file.
I have tried modifying the bend radius but this doesn't seem to help.
Steve
Message 7 of 11
JDMather
Forget you ever saw the Fold command - you should (almost) never need it.
This is not the correct way to model this part.
I have to run now - but will post the correct solution when I get a chance.
In addition to the interferences - if I set Measure results to dual units and all decimals - none of your dimensions make logical sense, another reason to never use Fold.
Message 8 of 11
johnsonshiue
Hi! The flat pattern fails to create due to the bend zone crossing the circular bend relief. I use Direct Edit command to make the bend relief from 0.125 to 0.15. Then fix up a few bend sketches since they were associative to the geometry created before Direct Edit. Please take a look at attached part. It should work.
Many thanks!
Software Test Engineer
Message 9 of 11
Finally, an answer I can actually use!  Thank you for looking into this, it was very helpful.
Message 10 of 11
JDMather
What about the impossible feature interference?
What about the finished form dimensions?
Message 11 of 11
IgorMir
Hi JD,
I guess - it is irrelevant nowadays! LOL! As well as fully constrained sketches and robust modeling practice.
Cheers,
Igor.
Web: www.meqc.com.au
