Create flat pattern of tank assembly
I have a model of a storage tank that I am currently detailing. I would like a view on the drawing of the tank unrolled so I can dimension heights of all nozzles and supports on a single view. (basically I want a view like a flat pattern of a rolled sheet metal part, but as an assembly).
Does anyone know if this is possible? Any thoughts or work-arounds to achieve this?
JDMather
Yes, if done properly this is possible.  Not sure correct solution would be called a "work-around".
Thanks for the reply. Do you know if there is a tutorial or other discussion describing how to create this?
a.amirNVP3B
how can this be done please?
I want to learn how to do that. Each time I have to do shell development I have to draw the strakes myself and the nozzles' cut outs and when some positions change, I have to re modify it by myself.
It is time consuming and there is a risk of error as well associated also. Thanks. Looking forward to your reply.
HAFEZ AMIR Mohammad Anas.
kacper.suchomski
https://youtu.be/yLk9Ogxr1aM?feature=shared
Kacper Suchomski
YannickEnrico
Something similar was discussed here
https://forums.autodesk.com/t5/inventor-forum/sheet-metal-planificacao-unidos/m-p/12554510#M920060
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
