The crash report of the Autodesk Inventor Software is send with the wrong e-mail address.
How to change that?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
Solved by bradeneuropeArthur. Go to Solution.
On behalf of @johnsonshiue who came with this solution.
Hi Arthur,
It seems to be associated with the following registry key, which was created on install or first use."Email" in "Computer\HKEY_CURRENT_USER\SOFTWARE\Autodesk\SendMiniDmp\Settings"
Arthur Knoors
Hi! I am Johnson Shiue. I approve this message.
Many thanks!
