Inventor Forum
Copying
5 REPLIES 5
357 Views, 5 Replies
Copying
If I use two inventory at once, how can I copy one measurements and sketches to another? Inventor 2019
R.
5 REPLIES 5
andrewiv
You cannot.  Here is a post on the idea station that could resolve your request.  https://forums.autodesk.com/t5/inventor-ideas/drag-and-drop-between-inventor-sessions/idi-p/9115694
Andrew In’t Veld
Designer
johnsonshiue
Hi Ronald,
I believe it should work. Are they different Inventor releases or the same Inventor release? You can copy and paste sketches or numbers between sessions.
Many thanks!
Software Test Engineer
in reply to: johnsonshiue
I have opened two of the same programs on different screens but don't let them copy
andrewiv
What version are you using?  I'm using 2020.3 and I cannot copy/paste a sketch from one session to another session, however you can copy dimension values using the standard Ctrl+C/Ctrl+V windows functionality.  This is just copying the text and not the entire dimension.
Andrew In’t Veld
Designer
johnsonshiue
in reply to: andrewiv
Hi Folks,
Sorry for my misinformation! I thought it was supported but it is not. Copy&Paste across multiple sessions is not supported unfortunately. I think only across documents in the same session is allowed.
Many thanks!
