If I use two inventory at once, how can I copy one measurements and sketches to another? Inventor 2019
R.
You cannot. Here is a post on the idea station that could resolve your request. https://forums.autodesk.com/t5/inventor-ideas/drag-and-drop-between-inventor-sessions/idi-p/9115694
Andrew In’t Veld
Designer
Hi Ronald,
I believe it should work. Are they different Inventor releases or the same Inventor release? You can copy and paste sketches or numbers between sessions.
Many thanks!
I have opened two of the same programs on different screens but don't let them copy
What version are you using? I'm using 2020.3 and I cannot copy/paste a sketch from one session to another session, however you can copy dimension values using the standard Ctrl+C/Ctrl+V windows functionality. This is just copying the text and not the entire dimension.
Andrew In’t Veld
Designer
Hi Folks,
Sorry for my misinformation! I thought it was supported but it is not. Copy&Paste across multiple sessions is not supported unfortunately. I think only across documents in the same session is allowed.
Many thanks!
