Can anyone tell me if you can copy an Individual feature in a model and reuse that feature in the same model on a different surface.? I am using Inventor 2017 in Windows 10. The clipboard is grayed out.
Solved by johnsonshiue. Go to Solution.
Hi! Generally speaking, most sketch-based features (extrude, revolve, and hole) with any placed features (fillet and chamfer) can be copied from one part and paste to another (or within the same part). Whether or not the operation will work depends on how the features are created and what features are involved. If a set of features can be copied and paste successfully, they can also be extracted as an iFeature to be reused.
If you are encountering an issue, please feel free to post the part here or send it to me directly (johnson.shiue@autodesk.com). I can take a look and tell where the problem is.
Many thanks!
