Converting Inventor Surface Models to Solid
Mohammad.choudhary
Message 1 of 26
Mohammad.choudhary
I appreciate this topic has been discussed numerous times however I have spent hours researching watching videos of how to repair a surface model into a solid model. Is there a simple method of converting surface to solid? Can you convert to solid from importing window?  I am importing a SAT file into inventor and converting to an .IPT.  I have attached a typical file I need converting to a solid. Any help would be appreciated.
Replies (25)
Message 2 of 26
JDMather
Do you have an image or link to what this is supposed to represent in the real world?
What is the source of the original geometry?
Can you Attach the native file from the source?
Message 3 of 26
Mohammad.choudhary
Below is the link to what this is supposed to represent in the real world:
https://www.spirotech.co.uk/products/spirotop/spirotop--brass--hight-158/
I have attached the native file. I am exporting the native file to .SAT and importing into Inventor.
Message 4 of 26
JonathanKruger
Could you share the SAT file you are importing?
If this solves your issue please mark this posting with the "ACCEPT SOLUTION".
If you like something that was said or if it was helpful, Likes are appreciated. Thanks!
Message 5 of 26
Mohammad.choudhary
I am unable to attach the .SAT file but I have attached the Revit file .RFA
Message 6 of 26
JonathanKruger
Can you zip the SAT file and then it should allow you to attach  the zip file?
Message 7 of 26
Mohammad.choudhary
I have zipped the .SAT and .RFA files for you.
Message 8 of 26
-niels-
Message 9 of 26
Mohammad.choudhary
Yes
Message 10 of 26
-niels-
If you haven't already, i'd suggest creating an account there then and download it from that site instead.
They offer many filetypes including Inventor, so you can skip the entire conversion of the .RFA file.
It's a great site with loads of different supplier content.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 11 of 26
cadman777
In the past, in cases where a vendor did not supply 2d or 3d files for their parts on their web site, and when I could not find them on an alternative we site like @-niels- has shown, I took the time to make it from scratch in Inventor. If I was going to use it in different sizes, I made sure I thought through how to make it so I can make an iPart or easily update it to the correct sizes when changed. This process takes time, especially with gear reducers. But today, almost anything is available online if you look hard enough. I have read in the past that going from Revit to Inventor and vice versa can be a problem.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 12 of 26
TheCADWhisperer
Is there a reason that you cannot use as a Surface Body rather than as Solid Body?
Message 13 of 26
cadman777
I just opened the SAT file.
The stupid translator created 3 separate part files for this single part.
It should have created only 2 parts:
  1. the main body
  2. the threaded insert at the bottom.
So you have to do some work to fix this if you want to use it.
First thing you need to do is separate the 2 true parts.
Then join all the rest of the solids & surfaces of the main part into one part.
The way I did that is open one of the parts and derive the other parts into it.
Then delete all the unwanted features and export it as a STEP file.
Then reopen the STEP file and save it as a part file (ipt) and do your edits to make it a solid.
Here's how I did that:
Find where all the separate features join and figure out which surfaces are unnecessary.
Delete them and take another look at the surfaces where they joined.
Also look at which faces are defective.
Delete all the features you don't need, whether defective or good.
Where the top nut joins the body needs work.
The end faces of the top nut also need work
You will also see defective faces on some of the chamfers that need work.
You have to delete all those bad faces and remake them.
After doing all of that, then Stitch everything together and you should have a complete solid.
Same with the other (small) part.
This process took me about an hour to do.
See attached model to visualize my work-flow.
The lesson in this is to see if you can find the part online for free.
That could save a lot of time.
But sometimes it's just easier to make it from scratch as a native Inventor part, or do what I did to this vendor part.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 14 of 26
cadman777
Inventor 2010 did this to the SAT file.
Is this how yours came in?
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 15 of 26
SBix26
Unless the solid body is needed for additional editing or for material properties (volume, mass, etc.), I agree with @TheCADWhisperer , there is no benefit to spending the time to make it solid.
Inventor 2023 offered the option of opening the .SAT file as a multi-body part file or an assembly.  I opted for the part file, then turned off translucent surface appearance and gave the surface body the same appearance as the solids.  Now it looks like it's ready to drop into your assembly.
Sam B
Inventor Pro 2023.0.1 | Windows 10 Home 21H2
Message 16 of 26
Mohammad.choudhary
Thank you, this would work in this instance as the part is available - but i would like to learn how to fix this issue.
Message 17 of 26
Mohammad.choudhary
Inventor brings mine in like this
Message 18 of 26
Mohammad.choudhary
This looks good !!
Would there be a video of how you did this. I would like to learn how to fix this issue in the future. I agree with the others, the easiest option is to find the part from a library but in the instance its not available I would like to at least know how to solve the problem. I struggle with repairing the geometry for example identifying the bad faces and features.
Message 19 of 26
JonathanKruger
Toggle the surface to not be Translucent
Message 20 of 26
Mohammad.choudhary
when I do this it doesn't look right.
