Inventor Forum
converting .idw to .dwg
8 REPLIES 8
Message 1 of 9
1599 Views, 8 Replies
When I convert my .idw from inventor to a .dwg for autocad my hidden lines become solid lines, how can I fix that to keep them as hidden lines?
8 REPLIES 8
Message 2 of 9
mwighton
Did this post help out? Hope it did.
If so please use the 'Accept as Solution' or 'Kudos' Button below.
God Bless
Mwighton
Message 3 of 9
in reply to: mwighton
I understand how to convert the files. What I am asking is why when I convert the files do the hidden lines and center lines become solid lines in the autocad .dwg file?
Message 4 of 9
Binga
Can you share the file?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn
LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Message 5 of 9
in reply to: Binga
Not sure if Im doing this right but attached should be both the autocad file and the inventor file.
Message 6 of 9
Binga
Here the conversion is ok
Can you see if your styles is this way?
Make sure that the "Hidden (ANSI)" in set dashed.
One workaround is: You can change the layer Hidden in AutoCAD
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 7 of 9
in reply to: Binga
Here is how it shows up for me and the machine shop that we use... My other designers dont have autocad just inventor so they cant by pass it by changing it in autocad..
Message 8 of 9
Binga
Yeah. I oppened you archive here and it is like your picture (without the dashed linies). Have you checked the styles in Inventor?
Gilberto Binga
Facebook | LinkedIn
LOUCO POR AUTODESK
Message 9 of 9
in reply to: Binga
Ahh yes I see it now thank you problem solved
