When I convert my .idw from inventor to a .dwg for autocad my hidden lines become solid lines, how can I fix that to keep them as hidden lines?
Solved by Binga. Go to Solution.
I understand how to convert the files. What I am asking is why when I convert the files do the hidden lines and center lines become solid lines in the autocad .dwg file?
Gilberto Binga
Engenheiro Mecânico - Engenheiro Mecatrônico
deLearning - YouTube Channel
Facebook | LinkedIn LOUCO POR AUTODESK
A resposta resolve seu problema? Ajude outros usuários marcando "Aceitar como Solução"
Does the answer solve your problem? Help others checking "Accept as Solution"
Curtidas são apreciadas caso tenha gostado da informação
Likes are appreciated if you liked the information.
Not sure if Im doing this right but attached should be both the autocad file and the inventor file.
Here the conversion is ok
Can you see if your styles is this way?
Make sure that the "Hidden (ANSI)" in set dashed.
One workaround is: You can change the layer Hidden in AutoCAD
Gilberto Binga
Here is how it shows up for me and the machine shop that we use... My other designers dont have autocad just inventor so they cant by pass it by changing it in autocad..
Gilberto Binga
