Inventor Forum
Content Centre thumbnail view
11 REPLIES 11
Message 1 of 12
1424 Views, 11 Replies
When using Content Centre, in the Favourite’s section, the Tree View will not default to Thumbnail View. Every time I close the Content Centre it reverts back to Tree View.
Any ideas on a solution?
(See attached screen shot)
11 REPLIES 11
Message 2 of 12
Yong.Jing
All the Content Center settings file is located at C:\Users\<current user>\AppData\Local\Autodesk\Inventor 2012\Content Center\Settings.
You could find search result, favorites, history and etc.
But there is a limitation to let the thumbnail view as default viewing.
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
Message 3 of 12
in reply to: Yong.Jing
Is this possible yet? (2014)
Message 4 of 12
No???
Message 5 of 12
-niels-
I just gave it a quick try and it doesn't seem to remember that setting in 2014 either.
I do get little "thumbnails" next to the parts in tree view, not sure if those were always there...
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 6 of 12
Yong.Jing
in reply to: -niels-
For 2014, if you use server content center, the thumbnail is located at C:\Users\\AppData\Local\Autodesk\Inventor 2014\Content Center\PC\Thumbnail
Yong Jing
Message 7 of 12
Does it still revert back to the Tree View?
Message 8 of 12
yes
Message 9 of 12
Will this ever be fixed?
Message 10 of 12
johnsonshiue
Hi!  This is an old thread. I am sorry I am a bit lost here. Do you mind starting a new thread with the behavior you are seeing? Or, add some snapshots describing the behavior.
Many thanks!
Software Test Engineer
Message 11 of 12
in reply to: johnsonshiue
Hello Johnson,
it's about to pin the preference view on Content Center Favorites (see images attached). We have two options for the icons view : Tree View and Thumbnail View.
If we set the Thumbnail View (large icons -> easy to understand and select) when call again the Place from Content Center the view for the Favorites is set back to default Tree View.
Our requirement is to pin the preference view on Content Center Favorites once set and maintain it.
With many thanks,
Lucian Crisan
Autodesk Inventor Professional 2018
Vault Professional 2018
Message 12 of 12
jan_priban
you are right, Favorites defaults to Tree View every time when Content Center is open. Thank you for the tip of possible future improvement.
Regards
Jan Priban
