Hi
I am new to Inventor and have some trouble with creating an internal gear.
https://forums.autodesk.com/t5/inventor-forum/internal-bevel-gears/td-p/5954862
This post helped me a lot with my work, so I was able to create the gear surface from the 2D sketch on the left.
My goal is to create the 3D solid of this internal bevel gear so that I can 3D print the prototype.
I simply tried to loft a solid from the 2D sketch but selecting two sketches on top and bottom for solid lofting was somehow not possible.
As...a result, the lofted surface on the right was the best result I could build.
Any suggestion to build a solid gear from here?
