I do this quite a bit myself with self-generating part descriptions using iLogic. The trick is to concatenate your text together and the command syntax can get you if you're not familiar with it. If you have a carriage return, you can't have anything interrupting the concatenation, not even a remarked line. Use the "&" symbol as the concatenate (join) command. For example:
This works:
iProperties.Value("Project", "Description") = "My(Part)Is " &
Length & 'Length is a variable somewhere
chr(34) &
"long"
and would produce a result of: My(PartIs) 12" long.
However this wouldn't work:
iProperties.Value("Project", "Description") = "MyPartIs " &
Length &
chr(34) &
"long"
The remarked line " 'Length is a variable somewhere " interrupts the sequence as it's on a new line, but works just fine at the end of a line.
Placing your special characters within the quotes or using the chr(?) feature works just great.
Good luck!
Autodesk Inventor Certified Professional
