Constraint offset dropdown box
jlarose
jlarose
Can anyone tell me if you are able to increase the number of previous entries shown in the constraint offset drop down box? It currently shows 'Measure' and then your previous 5 entries. I would like to be able to increase this number.
Thanks ahead of time for any help you can give me.
kacper.suchomski
Hi
There is no such setting.
Maybe it can be programmed into the API, but that's a question for @bradeneuropeArthur
Kacper Suchomski
bradeneuropeArthur
@kacper.suchomski thanks for mentioning me!
I think this could be found anywhere in the registry
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
johnsonshiue
Hi! Unfortunately, no. There is not available. Only the last 5 used values are listed. We are in the process of modernizing the UI. In theory, this could be taken care by the presets.
Many thanks!
Software Test Engineer
bradeneuropeArthur
@johnsonshiue That seems to be true.
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersionXX.0\System\Preferences\Most Recently Used Values\Constraint Modifier\Constraint Modifier Value
Also here you can add a additional value MRU6 with no succes
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
