Inventor Forum
Constraint moving opposite direction
8 REPLIES 8
Message 1 of 9
lkirit2000
474 Views, 8 Replies
Hi
Please see the attached image, the inner pipe should move upwards, but it goes opposite direction. How to fix ?
8 REPLIES 8
Message 2 of 9
WHolzwarth
in reply to: lkirit2000
That's hard to tell without looking at the files and their constraints  Smiley Wink
Walter Holzwarth
Message 3 of 9
CCarreiras
in reply to: WHolzwarth
Hi!
Try using negative values.
CCarreiras
Message 4 of 9
lkirit2000
in reply to: CCarreiras
Hi
I have already tried applying negative values, but didn't work.
Rgds
Kiri
Message 5 of 9
Attach your assembly here or a similar assembly that exhibits the same behavior.
I have never had a logic assembly that did not work.
Message 6 of 9
Hi
Please see the attached compressed file.
When the Position in Master the top inner tube move towards down ( mate constraint +400)
Again the max it goes towards up ( mate constraint +400 ) .
Rgds
Message 7 of 9
Did you use Pack and Go from the top level assembly?
Message 8 of 9
Hi
I just compressed the all files.
Rgds
Message 9 of 9
If you compressed ALL of the files, why are some showing as Unresolved?
