hi guys, im relatively new to inventor,
how do you connect the circle surface to the flat surface so it turns out to by one slopey surface?
thanks
Solved by Xun.Zhang. Go to Solution.
Solved by TheCADWhisperer. Go to Solution.
Replace Face?
Edge Fillet?
Face Filet?
Split, Delete Face, Boundary Patch... ... so many ways.
Can you Attach your *.ipt file here?
Do you have an image of something similar to your design?
