Looking for some tips/direction on how to clean up an imported IGES file. Ultimately, it's a place holder in a 3D layout, but I need it to not have all these lines running through it.
For example, on this panel it's cut into two triangles. How can I combine these and just make it a single surface?
Solved by kacper.suchomski. Go to Solution.
Hi
Use Delete face tool (select repair mode on dialog box).
Kacper Suchomski
