I have been trying to recreate a sheet metal part from a step file with a bend radius of .787" . But I would like to change the bend radius to .75". Would there be anyway I could edit the radius directly from the step file on inventor? Or would I have to create the part on inventor from scratch?
Solved by kacper.suchomski. Go to Solution.
Just to be clear - the original geometry was not modeled correctly - so we will have to fix that as well.
What is your desired Bend Radius (inside radius)?
Oops - I see that in original problem description.
What version of Inventor are you using?
Hi
Look this:
Kacper Suchomski
Here is one way to do it (Inventor 2021 format).
Reasonably quick process.
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
