Inventor Forum
Design accelerator won't recognize certain holes.
12 REPLIES 12
Message 1 of 13
JBEDsol
488 Views, 12 Replies
Sometimes I'll hover over a hole looking to setup a bolted connection and it won't recognize the hole.  I can't seem to find any rhyme or reason why this happens.  Every now and then I make a part, add holes, and when I bring it into a larger assy I can't use the design accelerator for bolts.
12 REPLIES 12
Message 2 of 13
anthonyzepeda1969
in reply to: JBEDsol
I posted the same question awhile back and never got an answer. It's weird sometimes it works and sometines it doesn't.
Message 3 of 13
Gabriel_Watson
"the Bolted Connection generator is not able to identify holes in a Mirror feature. Workaround for this issue is to use 'Concentric' type of connection instead of 'By Hole' and select all cylindrical faces (diameter edges)."
https://forums.autodesk.com/t5/inventor-forum/cannot-select-the-hole-to-add-a-fastner/td-p/7841111
Message 4 of 13
anthonyzepeda1969
My case was not a mirrored feature.
Message 5 of 13
Hi, is it possible to add the part example (and version in use) ?
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
Message 6 of 13
This was a long time ago I think a year ago. Don't even remember which
project it was lol.
I've moved on since.
Message 7 of 13
LT.Rusty
in reply to: Gabriel_Watson
Addendum to that- it's not just mirrors. It also won't identify holes in any kind of derived part, including places where a multi-solid was spun off into separate parts in an assembly. Same thing happens in the drawing environment, when you're trying to dimension your holes and threads.
Rusty
Message 8 of 13
JDMather
@JBEDsol
Attach file here that exhibits this issue.
Make up a dummy file if necessary.
1. Must be a Hole feature. (An extruded cut circle is not a Hole feature, although might be other ways to use that.)
Message 9 of 13
FINALLY! That makes sense. So it has to be a hole feature created in Inventor?
I have tried to match to imported step files and I have no control how they were created. Sometimes it works and sometimes it doesn't most of the time it does not.
Thank You for that answer.
Message 10 of 13
@anthonyzepeda1969
You can use Feature Recognition add-in to translate cylindrical cuts from STEP files into Hole features.
Message 11 of 13
Ahhhh didn't think about that. That's an Add0In feature though?
Message 12 of 13
@anthonyzepeda1969
Free to subscription license - from the Autodesk App Store.
Message 13 of 13
Thanks found it.
Technology Administrators
