Inventor Forum
Changing sheet metal bend radius of a step file on inventor?
7 REPLIES 7
Message 1 of 8
Vishnu_k
351 Views, 7 Replies
I have been trying to recreate a sheet metal part from a step file with a bend radius of .787" . But I would like to change the bend radius to .75". Would there be anyway I could edit the radius directly from the step file on inventor? Or would I have to create the part on inventor from scratch?
Tags (1)
7 REPLIES 7
Message 2 of 8
JDMather
in reply to: Vishnu_k
@Vishnu_k
Can you Attach your file here?
Message 3 of 8
Vishnu_k
Message 4 of 8
JDMather
@Vishnu_k
Just to be clear - the original geometry was not modeled correctly - so we will have to fix that as well.
What is your desired Bend Radius (inside radius)?
Oops - I see that in original problem description.
What version of Inventor are you using?
Message 5 of 8
Vishnu_k
inventor professional 2021
Message 6 of 8
kacper.suchomski
Hi
Look this:
Kacper Suchomski
YouTube - Inventor tutorials | WWW | LinkedIn | Instagram
Message 7 of 8
SBix26
Here is one way to do it (Inventor 2021 format).
  • Converted to Sheet Metal, set defaults in Sheet Metal rule
  • Deleted all faces except the three flat inside faces
  • Extended those faces to sharp corners
  • Filleted corners to the desired bend radius
  • Thickened to Thickness.
  • Created flat pattern
Reasonably quick process.
Sam B
Inventor Pro 2024.0.1 | Windows 10 Home 22H2
Message 8 of 8
Vishnu_k
@kacper.suchomski .Yup. That works. Thanks
Technology Administrators
