Changing Display name of Content Center Part
ZacRocket
ZacRocket
Hi, I am just starting to dip my toes into custom content centers and I am trying to define the as standard Display name (or whatever we call the name in the model browser, see picture). From what I have found this has to do with the way I map my Template Parameters, but I am not sure how to map this together.
Desired Display name: Part number  + Size Designation
Current Display Name: Family name + Size Designation (As Seen Below)
SBix26
This is very likely determined by the column properties in the family table.  In the FT, find the Display Name column and right click in the column header > Column Properties.  There you should see the expression that creates the column entries from other data, such as Part Number, size, etc.  This is basically a string (text) operation.  If you need help with creating or altering an expression, let us know.
Sam B
Inventor Pro 2023.1 | Windows 10 Home 21H2
ZacRocket
@SBix26 Thanks for responding so quickly. It took me a minute to understand what you were saying/
I didn't find a Display Name column in my FT (Family Table I assume) So i made one. Added Catagory.png
However when I went to plug in a bolt instead of the Name Column it showed the Designation Column as it had been doing before.
I was wondering if the settings are messed up on the Parameter mapping so here is what my template parameters are set to
ZacRocket
I figured it out. I was being dumb. The Display name is defined by the "Member:Display Name" Template Parameter. However I placed it on two columns therefore it was redefining one of my Family Table columns then pulling from that column
