can I double click a dimension to edit without 'making sketch visible'?
Hello all,
Does anyone know if there is a setting that I can change to where I can edit a part dimension without having to make the sketch (or sketch dims) visible?
In other CAD systems I'm used to clicking the feature, the dimensions show up, then I can double click the dimension I need to edit, then regenerate. No need to go into sketch mode.
I can sort of do this if I were to click the feature > click make sketch visible > then double click the dimension to edit > then regenerate > click the feature again > click make sketch invisible
This is basically what I'm looking to do, but there's 3 or 4 more clicks than I'm used to for every single dimension I need to edit (which is a lot!).
Right now it seems just a tad quicker to right click edit sketch in the model tree to edit, but this throws me into sketch mode, and reorients the view, which is just a preference thing, but also takes a bit longer as well.
I'm hoping there's a setting that might be able to maybe make sketch invisible upon regenerate (or something similar)? Those microseconds add up
(Inventor 2023, btw)
