Chamfer with Ball end mill
jdthe09
Message 1 of 11
jdthe09
Can anyone tell me how to mill a chamfer on the outside of the cube using a ball-end mill?
I can't rotate the cube, which is why I'm using a ball-end mill—the image is just for illustrative purposes. I'm really just wondering if this is possible with Inventor CAM?
Replies (10)
Message 2 of 11
kacper.suchomski
Hi
Yes, it's possible. Please upload your file only after you've defined your CAM settings and added the remaining operations.
Kacper Suchomski
Message 3 of 11
jdthe09
Here's a STEP file. Thanks in advance for your help.
Message 4 of 11
kacper.suchomski
Please share a file with a tool library, with defined stock and operations preceding chamfer machining.
Kacper Suchomski
Message 5 of 11
jdthe09
Everything should be included in this STEP file; I've now added the ball-end mill to a projection. The zero point is set in the setup, and there is no prior machining. the blank is already included in the setup.
Message 6 of 11
kacper.suchomski
No. Step files are used to transfer geometry information only. Please attach an ipt file containing all the technological information.
Kacper Suchomski
Message 7 of 11
jdthe09
Oh, okay, I didn't know that. Thank you. Here's an .ipt file.
I can't seem to get it to display the raw material at the chamfer, but that's where the chamfer is supposed to be milled.
Message 8 of 11
kacper.suchomski
You can use e.g. Flow strategy.
(view in My Videos)
Kacper Suchomski
Message 9 of 11
jdthe09
Thank you. Can I use that on the underside too, so that the entire chamfer is machined?
Message 10 of 11
kacper.suchomski
I'm not sure if this is even possible using the available strategies.
It can be done brute-force method, but it would require a lot of manual labor.
Why can't you rotate an object in a holder? Is this some kind of school assignment?
Kacper Suchomski
Message 11 of 11
jdthe09
No, unfortunately not 😅. It was more out of curiosity than necessity. I wanted to machine it this way because I wanted to avoid having to swivel the part to save time (mass production). The problem is that the machine can’t move far enough in the Y-axis to machine the part with a chamfering cutter. That’s why I wanted to machine it this way—it would kill two birds with one stone. I’ve now solved this by rotating the part 45 degrees and then using the strategy you suggested. This worked for me at a minimum of 20 degrees, using a lollipop cutter with a 10 mm diameter and a 6 mm shank. Thank you again for your help.
