Inventor Forum
Chamfer bended L sheet metal
3 REPLIES 3
johan.degreef
218 Views, 3 Replies
I was looking for the easiest way to chamfer a bended L plate, so I can put 4 of these in a square. Should include spacing to weld properly with respect to outer dimension 300mm.
Many Thanks for helping
Inventor 20250, Vault Professional 2025, Autocad Plant 3D 2024
3 REPLIES 3
IV can do all 4 sides at once.
Maybe cut out what you don't need?
CCarreiras
in reply to: johan.degreef
Hi!
The "problem" in this case is the cut in the fold... it must be created in a particular way so we can flat the part later.
Fortunately, the cut tool has that option available to cut across the bend. (No unfold/refold needed)
This is what I should use to achieve this part.
CCarreiras
BDCollett
I would just create it as a multibody sheet metal part, and then make part from one of the sides and pattern it.
Then it's easy to go back and adjust the reliefs etc as you need.
