I was looking for the easiest way to chamfer a bended L plate, so I can put 4 of these in a square. Should include spacing to weld properly with respect to outer dimension 300mm.
Many Thanks for helping
Solved by BDCollett. Go to Solution.
Solved by CCarreiras. Go to Solution.
Solved by Frederick_Law. Go to Solution.
Hi!
The "problem" in this case is the cut in the fold... it must be created in a particular way so we can flat the part later.
Fortunately, the cut tool has that option available to cut across the bend. (No unfold/refold needed)
This is what I should use to achieve this part.
I would just create it as a multibody sheet metal part, and then make part from one of the sides and pattern it.
Then it's easy to go back and adjust the reliefs etc as you need.
