Certain hatch patterns not being printed
Message 1 of 59
After upgrading to 2016, certain hatch patterns are not being printed. Look at following example
In Inventor:
PDF file:
It looks like certain hatch patterns are not getting printed regardless of line weight, colour, etc.
Anyone had similar issue?! Smiley Frustrated
Replies (58)
Message 41 of 59
johnsonshiue
Hi! Many thanks for providing an example! But, I cannot reproduce the behavior on R2/SP1 build 210. Could you take a snapshot of Inventor Help -> About? I want to know what exact build you have on your machine.
Thanks again!
Software Test Engineer
Message 42 of 59
I attached screenshots of the application manager showing the install and the build. Although I am not on the same build as you mentioned.?
Message 43 of 59
ChrisMitchell01
Daryl,
SP1/R2 didn't install properly for you. You should be seeing build 210 in Help About.
Can you please look in your %temp% folder & zip up the most recent files called "Autodesk Inventor 2016 R2" "Autodesk Inventor 2016 SP1" "Autodesk Inventor Professional 2016 SP1.log" "Autodesk Inventor Professional 2016 English Language Pack SP1.log" & attach them here ?
Chris
Chris Mitchell
PDMS Customer Engagment Team
Message 44 of 59
There is nothing in my temp folder. This is in the application manager folder and this is all I can find.
Message 45 of 59
ChrisMitchell01
OK, could you also check under c:\windows\temp & C:\Users\XXXXX\AppData\Local\Temp ?
If you don't have any log files, then what happens if you simply double click that file ?
Chris
Chris Mitchell
Message 46 of 59
Found em.
Message 47 of 59
When I run the installer it installs:
Force effect plugin
Content IDF library
Nastran silver
Stress analysis
Shelby + enabler
But it still shows build 138
Message 48 of 59
ChrisMitchell01
Daryl,
I believe this is due to a legacy issue where an incorrect version of 2016 Update1 was released for a short time & then when it was re-released it was possible to reapply the new Update1 without first removing the previous update1.
We'll investigate this further, but in your case I would suggest:
1. Remove R2 if possible - using this command in a cmd prompt:
"C:\Program Files\Autodesk\Inventor 2016\Bin\UninstallTool.exe" R2
2. Remove Inventor 2016 English Language Pack SP1 using this command:
Msiexec.exe /uninstall {C2B4B6F5-2010-1033-0064-E0CB94366A9C} /package {7F4DD591-2064-0001-1033-7107D70F3DB4} /qb
3. Remove Inventor 2016 SP1 using this command:
Msiexec.exe /uninstall {C2B4B6F5-2000-1000-0064-E0CB94366A9C} /package {7F4DD591-2064-0001-0000-7107D70F3DB4} /qb
4. Remove Inventor 2016 Update 1 (Inventor SP1 supesedes it)
Msiexec.exe /promptrestart /qb /uninstall {D9AD67F6-F5D8-4377-8826-01687953EF10} /package {7F4DD591-2064-0001-0000-7107D70F3DB4} SETUP=1
5. Reboot
6. Install R2 again.
Far from ideal I know....
Chris
Chris Mitchell
Message 49 of 59
I will give it a try. Thank you for all the help with this. Much appreciated.
Message 50 of 59
That did it. Build is correct now and custom hatch patterns are indeed plotting now. Thank you to everyone for seeing this through to the end.
Message 51 of 59
ChrisMitchell01
Thanks for confirming Daryl & sorry it was so arduous.
-Chris
Chris Mitchell
Message 52 of 59
I may be dense here but I am having a hard time following how to get this issue resolved can someone point me in the right direction to find out what sp and version of inventor i am running and then after that info is provided finding the correct fix for my software I am not showing anything pending as far as updates in my autodesk application manager.
Message 53 of 59
Mark.Lancaster
@Anonymous
Go into Help/About Inventor and it will tell you.  Take a screen shot and post here if you want
Inventor 2016 updates are here; https://knowledge.autodesk.com/support/inventor-products/downloads
Mark Lancaster
Message 54 of 59
Here is a screenshot. Thank you in advanced for your time
Please be aware that this is a public forum posting serial numbers or personal information is not advised
Edited by
Discussion_Admin
Message 55 of 59
You need to go thru the same steps I did that Chris laid out a few post earlier. You should be on build 210.
Message 56 of 59
Mark.Lancaster
@Anonymous
You still have the release to manufacturing (or original) version.  Use the link I provided and update to SP1.  If you are on an active subscription then download and install R2/SP1 version.
Mark Lancaster
Message 57 of 59
SBix26
Don't post your serial number!!  The whole world can see it here.
Sam B
Message 58 of 59
fbuhnemann
Hello Chris,
I also have the problem with hatch patterns not working and SP not willing to install - so I tried out what you said but I couldn't reach to success - maybe
because I have a french language pack ?
Builing Design Ultimate 2016
On trying to run the R2/2016 I got the message to look here but the page isn't working ...
http:/knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1328-when-installing-Update-1-for-lnventor-20
15.html
So please, could you please have once again a look into this ?  I have really a big need for help because I actually need to have a full use of Inventor to get th e job done !
Thanks - best regards - Frank
Message 59 of 59
ChrisMitchell01
Hi Frank,
Here is the updated page:
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
Typically there are 2 causes for such an error:
You need to uninstall the Franch Language pack & then reinstall it from:
https://knowledge.autodesk.com/support/inventor-products/downloads/caas/downloads/content/inventor-2...
If that doens't fix it then the likely cause is that the Building Design Suite's initial release didn't contain the correct release build of Inventor; that's why the initial page suggets downloading it again & then reinstalling.
Hope this helps,
Chris
Chris Mitchell
