CC files position
CC files position
ambrosiPZ23D
CC files position
ambrosiPZ23D
Hi everyone,
where is the setting in Inventor to ensure that the files generate by Content Center will be in it-IT  instead of en-US folder?
Thanks for your help
Massimo
CGBenner
@ambrosiPZ23D
Hello, Massimo.  I believe that this is set by default based on the language pack you have installed with Inventor.  For example, mine is installed by default in English.  The Default CC files location is set out of the box.  When I placed my very first component, the en-US folder was created.  Was your Inventor installed using English as the default?
@johnsonshiue does this sound right?
Chris Benner
johnsonshiue
Hi! I believe it is based on the Content Center language setting. Go to Manage -> Content Center -> Editor -> Tools -> Language Settings -> select "English."
Many thanks!
Software Test Engineer
