Cant Create Thread in Inventor 2017 while 2012 is Ok
Message 1 of 8
Dear All
Im familiar Inventor 2012 then creation Thread is Ok
But I in 2017, by that way i cant creat thread.
Anyone get this trouble, I hope get your solution. Help me to check attach files.
Thank you!
Replies (7)
Message 2 of 8
blair
It works fine here, make sure that you have the latest SP's and Updates installed for your version. Possibly check your extrusion diameter, I think the latest version checks the diameter to match the thread to the major diameter. Mine will through up an error stating an invalid thread.
Do you have both versions opened at the same time?
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
Message 3 of 8
Hi Blair
Thank you so much for your support
Could you help me more detail.
I dont know how to solve now.
Good luck!
Tuyên​, Nguyễn Ngọc​ | Phụ trách Kỹ thuật
*CTCP GIẢI PHÁP CÔNG NGHIỆP | INDUSTRY SOLUTION Co.*
*Nhà máy chế tạo thiết b*ị : Km25 Quốc lộ 3, Nguyên khê, Đông Anh, Hà nội
+84 904 883 061​ | Skype : solution061 | tuyen.nguyen@thietbicongnghiep.vn
| www.chetaothietbi.vn
GIẢI PHÁP LÀ TIÊN PHONG
Message 4 of 8
Hi Blair
Good luck!
Message 5 of 8
Dear Mr Blair
I can view your Ipt file but trying and still cant make new Thread for my part.
Hope have other solution.
Goodluck!
Message 6 of 8
Roelof.Feijen
Hello @Anonymous,
Can you check if the visibility of Textures is on?
Go to the Ribbon > View Tab > Appearance Panel > Textures On
Otherwise check your Textures folder.
Go to Tools > Application Options > Files tab
Check the setting of the Texture folder. Is it specified?
Does it contain Textures?
The default location should be C:\Users\Public\Documents\Autodesk\Inventor 2017\Textures
Roelof Feijen
If my post answers your question, please click the "Accept Solution" button. This helps everyone find answers more quickly!
Message 7 of 8
SašoPrijatelj
Inventor 2015 and earlier versions used an MS component named ADO for reading thread-related spreadsheets. This was changed in Inventor 2016. Now Inventor uses an Excel COM API call instead. Excel Starters and other low-end versions of Excel do not provide an API. Also Open Office or Office 365 are not supported as replacements for a full, locally installed Excel.
Solution:
As a temporary workaround, you can create the following Environmental variable:
Go to Control Panel > System> Advanced System Settings> System Properties, Advanced Tab.
Create a new Environmental variable called "UseLibXL" with a variable value of 1
Retry your clearance/threaded hole creation in Inventor.
This will attempt to use the 3rd party component in Windows instead of Excel. It doesn't support all aspects of what Excel provides but it should work for holes.
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Message 8 of 8
Wao !!!!!!!
Thank you so much, Mr saso
It is solved and run well for both Thread and Hole
You are so professional !
Thank you 2 again!
Good luck!
