Create Thread on 2017
It is ok to create thread in 2012 Inventor but in 2017 i get a trouble, point to thread then Extrude but it not show Thread Spec. Table. Help me to check it with detail in attach file.
Thank you
mcgyvr
Please post your ipt file..
I have no problems creating external threads in Inventor 2017
Is this the same computer you have 2012 loaded on?
Do you have excel installed on this computer? (please state which version of excel you have)..
Can you create a threaded "hole" using the hole command (thread option)
Dear Sir
Thank you so much for support!
It is solved OK by Mr Saso's guide.
Detail as :
Go to Control Panel > System> Advanced System Settings> System Properties,
Advanced Tab.
Create a new Environmental variable called "UseLibXL" with a variable value
of 1
Retry your clearance/threaded hole creation in Inventor.
Tuyên​, Nguyễn Ngọc​ | Phụ trách Kỹ thuật
*CTCP GIẢI PHÁP CÔNG NGHIỆP | INDUSTRY SOLUTION Co.*
*Nhà máy chế tạo thiết b*ị : Km25 Quốc lộ 3, Nguyên khê, Đông Anh, Hà nội
+84 904 883 061​ | Skype : solution061 | tuyen.nguyen@thietbicongnghiep.vn
| www.chetaothietbi.vn
GIẢI PHÁP LÀ TIÊN PHONG
Dear Sir
Detail as :
Advanced Tab.
of 1
Thank you
It is solved!
Good lucK!
You can give specific instructions on how to create
( Create a new environment variables mới gọi là "UseLibXL" for the value biến
là 1  )
