Inventor Forum
Cannot Update From Style Library
1 REPLY 1
bradeneuropeArthur
98 Views, 1 Reply
We see the following, that the styles cannot be updated to the latest style library definitions.
To show you I have taken a drawing with extremely changes to the Partslist; drawing dimensions; and ballooning.
Since there is no update possibility there will be possibly non standard/uniform drawings.
@johnsonshiue Do you have any idea what is wrong here?
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
1 REPLY 1
All library styles where deleted from the library and therefore the update was not possible.
Problem solved for the moment.
Arthur Knoors
