Inventor Forum
Cannot rename files in Design assistant
30 REPLIES 30
Message 1 of 31
CWC_Drawing_Office
1425 Views, 30 Replies
Hi all,
I need some assistance with the design assistant. I have files which I have exported from a master ipt file.
I would like to rename the master file and assembly files but when I open the files in the design assistant it says the files needs to be updated to the current inventor release, at which point I say okay and presume that the files have now automatically updated.
I cannot click on the action button to allow me to rename the file as it is not giving me the option.
All assistance is appreciated.
30 REPLIES 30
Message 2 of 31
@CWC_Drawing_Office wrote:
... and presume that the files have now automatically updated.
Design assistant will not update the files, you'll have to open them in inventor and save them there.
Niels van der Veer
Inventor professional user & 3DS Max enthusiast
Vault professional user/manager
The Netherlands
Message 3 of 31
Thanks for the reply, I opened the files in inventor and saved it. Closed the files, opened design assistant and it gave me the same message for the files I just opened and saved.
Message 4 of 31
Hm Niels is right. Normally it should work.
But just to be save you can try another thing.
Do a migration in the Task planer. It normally does nothing else then open and save.
But maybe there is went something wrong during your manually process.
Marcus Mertens
Automation / Planung and Simulation
Schmidt & Heinzmann GmbH & Co. KG
Industrial Machinery
76646 Bruchsal
Message 5 of 31
M.Mertens_S&H
in reply to: -niels-
Pictures of the Task planer. In case of you don't know what i mean. 😋
Regards...
Marcus Mertens
76646 Bruchsal
Message 6 of 31
@CWC_Drawing_Office  Check if your application options are set up for migrating on save properly:
(it might be set to not prompt and not save)
@M.Mertens_S&H  also gives a good method of migrating files through the task schedular.
Niels van der Veer
The Netherlands
Message 7 of 31
I was not set up for it, I changed it to yes. Reopened the files saved them, closed inventor, reopened design assistant and got the same message.
So The biggest problem I'm having is that I cannot rename the master file?
I rename it via windows and then when I open the assembly I have to point out what is the master file is, I select the renamed master file but it refuses to accept it.
Message 8 of 31
I have the same Problem sometimes. Just click Pass and then replace the file by right click in the Model Browser.
This should work
Marcus Mertens
76646 Bruchsal
Message 9 of 31
Am i correct in assuming your Master file is a multi-solid that you used "make components' on?
So you have an .ipt that is derived into multiple part files and those are collected into an assembly again?
If that's the case, can you re-link the individual part files to your renamed master?
Are you getting any error messages?
Manual renaming through windows explorer is a very forceful method for re-linking derived files, so i find it strange that it doesn't work...
Can you share the files? or give steps to recreate your situation?
Niels van der Veer
The Netherlands
Message 10 of 31
So I renamed the master file, opened the assembly, skipped the part where it asks me to specify the file.
At which point the assembly opens but the file is unresolved, I try to resolve the file by showing it to the newly renamed master file but it will not accept it. So weird.
Message 11 of 31
You are 100% correct.
So it's not the individual files thats the problem it is the assembly where all the parts have been sent to that isn't linked to the master.
I made a pack n go but I cannot load it onto the forum because theres multiple file formats that the forum doesn't accept.
Will be happy to share via email.
Message 12 of 31
Please disregard the attached files these were the only ones that loaded when I tried uploading the pack n go
Message 13 of 31
You could ZIP the files created by the pack&go, but i'm suspecting you'll need to re-link all the individual files first before opening the assembly.
My reasoning: if you used the method i described in my previous post, the master file is derived into the individual ipt's and not the assembly.
The assembly should keep the link to its files if they aren't renamed.
Niels van der Veer
The Netherlands
Message 14 of 31
The assembly definitely keeps it's links to the individual parts, so no issues there.
But I believe the individual parts are losing their link to the master, so If i have 200 parts that have lost the link and I rename the master via windows I will have to relink 200 parts to the newly named master file. That is why I wanted to use design assistant to rename the master but it wont allow me to.
Message 15 of 31
I can understand you don't want to manually link that many files and i do believe this should be possible with the Design Assistant.
I'm not sure what is going on if you resolved the migration issue.
(your image in the opening post showed that the master.ipt needed updating/migration)
What version of Inventor are you using?
In IV2022.1 they added the function to replace the base component for derived parts, which might help in certain cases...
Try posting your pack & go as a .zip if possible, not sure if i can help resolve your issue (nearing end of my workday) but maybe others can jump in and see what might be going on.
Niels van der Veer
The Netherlands
Message 16 of 31
SBix26
in reply to: CWC_Drawing_Office
Somewhere in your process something is wrong.  Design Assistant will definitely do what you are asking.
Have you opened the assembly and saved/migrated everything in it?  If so, close Inventor, then open the assembly in Design Assistant.  Drill down to find the master file and change the name there.  This should modify the links in all the part files that depend on the master file.
Sam B
Inventor Pro 2023.1.1 | Windows 10 Home 21H2
Message 17 of 31
Hi! Please zip up the P&G files and attach it here or send it to  me directly johnson.shiue@autodesk.com. I would like to understand the Design Assistant behavior better.
Many thanks!
Software Test Engineer
Message 18 of 31
Hi All,
Thanks for the replies.
Unfortunately I cannot zip the P&G as I have used a "³" character a few times.
Message 19 of 31
Hmm... that character did not give me issues creating a zip file, but it made me wonder...
Looking at your image, it seems you have quite a few subdirectories.
There might be a slight chance your path has too many characters and that might be interfering.
Can you try moving your files up a few directories and then using design assistant again?
Niels van der Veer
The Netherlands
Message 20 of 31
CWC_Drawing_Office
in reply to: SBix26
I did all of this and when I still bring the iam. into design assistant it says certain files must be updated. I opened the individual files and updated them all individually and same result.
