Hi Johnson
I should have elaborated a bit more. I was busy with a drawing at the time.
- I was using a dummy drawing to do a "Replace Model References"
= Copied a view to my main drawing
- Went back to the dummy to replace references again
- Replaced the model.
- Made a mistake, so I pressed the undo. However this is where the error might have arisen
- There were orphaned items at the time of pressing the undo button. Due to the model change, some geometry was slightly different and I did not clean it up before pressing undo. (I normally clean the view before doing anything)
- The undo then rolled back to the last save point.
One additional thing, Inventor was pretty much broken after this. I had to restart, as the relevant IPT and IAM files were missing from the file browser. (Insert panic here) After the restart everything worked just fine. I had lost all work done on the drawing, but at least the files were still present on the disk, and there was no corruption.
I did not do anything different after that and continued with the same workflow of using the dummy drawing to create new views. I just cleaned the views up before copying them.
I was partly to blame for this error, as working with unresolved orphaned items is not the smartest thing to do.
Reg
2026.1
