Cannot open Inventor Windows error
procenitelj
procenitelj
Hello everyone,
I had no problems with Inventor until few days ago when all Inventor files stoped opening. Windows just pops up this messege:22.JPG
I have Win10.
I tried with uninstall and reinstall but there were no effects.
Any suggestions?
Replies (21)
johnsonshiue
Hi! The error means the Inventor has been uninstalled and the executable cannot be found. You will need to re-install Inventor.
Many thanks!
Software Test Engineer
procenitelj
As I said at my post, I've reinstalled Inventor again and the error remains.
johnsonshiue
Could you go to the folder and see if Inventor.exe exists?
Many thanks!
procenitelj
It exists.
It doesn't either open documents, ipt, dwg, nothing. It always says that it cannot find the programe.
asiteur
Have you tried launching Inventor from the executable in the Program Files folder?
It sounds somehow as if there is some sort of antivirus process that interferes and denies error to the path.
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
procenitelj
I have tried, the error remains.
Mark.Lancaster
Use the following steps to re-register Autodesk Inventor with your operating system:
1.  Exit Inventor if still running
2a.  Win 8/8.1/10: Select the Windows start button and type CMD (but do not hit an enter)
2b.  Win 7:  Select the Windows start button and type CMD in the search field (but do not hit an enter)
3.  When CMD or command prompt appears in the list, right mouse click and select run as admin
4.  When the command prompt appears, navigate using dos commands to C:\Program Files\Autodesk\Inventor <version>\Bin or where your Inventor.exe is located if you changed the default install location of Inventor.
In this example I'm navigated to my Inventor 2018 (exe) location.
6.  Type Inventor.exe /install.
Wait a few mins and restart Inventor.   At this time you will not see anything occurring.  Don't panic.  Smiley Very Happy  However if you launch Windows task manager you can watch the Inventor.exe process (and see when it ends).
Does that resolve the issue?
Mark Lancaster
procenitelj
It still cannot find the path:
johnsonshiue
Hi! Please open File Explorer and go to C:\Program Files\Autodesk\Inventor 2015\Bin\. Take a screenshot showing Inventor.exe does exist there.
Many thanks!
procenitelj
Here it is:
johnsonshiue
Hi! What is the OS? Is it 32-bit or 64-bit? Inventor 2015 does have two different flavors (32-bit and 64-bit). You can only install 32-bit Inventor on 32-bit Windows and likewise 64-bit Inventor on 64-bit Windows.
Many thanks!
procenitelj
It is Win10 64 bit. I had no problems with Inventor 2 years and then suddenly it stoped working.
johnsonshiue
Hi! It is still a mystery to me why Inventor.exe is present but it cannot be run. It points to environmental or install related issues. Could you take a look at the following thread and see if it applies to you? The thread is for 2018 but I think it should work similarly to 2015 also.
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/discussion/t5/Installa...
Many thanks!
bradeneuropeArthur
In the screenshot of the application folder I can see inventor twice with no extension and one with extension. Please change your explorer options to hide known extensions to no. Than make a new screenshot. Maybe something wrong there....
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
procenitelj
I've just tried that solution and the error remains.
procenitelj
Here it is:
kelly.young
Autodesk Support
Autodesk Support
@procenitelj there have been some very good suggestions that aren't panning out.
Just a thought to investigate:
Random startup crash on systems with NVidia Quadro graphics cards
This seems to be an install launch file location issue, but wanted to check.
When you do a full uninstall do you go into the program files and delete any remnants before reinstalling?
Is there sufficient space on the hard drive available or is it maxed out?
Seems to be a difficult issue to pin down.
procenitelj
When I do a full uninstall I go into the program files and delete any remnants before reinstalling.
I've done a clean uninstal as said in: https://knowledge.autodesk.com/customer-service/download-install/remove-products/clean-uninstall
There is sufficient space on the hard drive available.
bradeneuropeArthur
Try this out:
https://www.youtube.com/watch?v=ZfJW_NYiilE
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
