Cannot Extrude/Emboss Edwardian script text
ddn996
ddn996
Community Visitor
Community Visitor
Hi, I'm on Inventor 2022 and having trouble with extruding/embossing a text in Edwardian font. It works fine with other fonts except this one. Can someone please help! Thank you
Alexander_Chernikov
This is a very complex font with many self-crossings.
If you still need this particular font, you can try to write the desired text in this font in AutoCAD,
then explode the text into polylines (using the Express Tool),
import the file into the Inventor sketch and then extrude
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Олександр Черніков / Alexander Chernikov
Facebook | LinkedIn
johnsonshiue
Hi! More than likely there is an issue when Inventor tries to convert the text in such font to a profile. You may want to try creating such text in AutoCAD and then use EXPLODE command to convert it to polyline. Then copy and paste it to Inventor. It may work better. Another approach is to use Fusion 360 instead.
Many thanks!
Software Test Engineer
kacper.suchomski
Hi @ddn996
It seems that Inventor has problems with specific characters. I checked Extrude and Emboss and they work with different words and sometimes they don't.
If none of the options work for you, then you actually need to break it down to Plines in AutoCAD.
Just remember to check the automatic creation of coincident constraints when importing geometry into Inventor.
For examples of DWG import methods into a sketch, see this thread:
https://forums.autodesk.com/t5/inventor-forum/dxf-dwg-into-inventor-problems/td-p/11669306
Kacper Suchomski
