nesting error
nesting error
89198826955
Message 1 of 8
nesting error
89198826955
Good afternoon. I want to pass a nest to Nesting, but I get an error, why?
Replies (7)
Message 2 of 8
cadman777
I don't use Nesting, but in order to get better help, it may be good to describe your work-flow and quote the error message or give a screen cap of it.
... Chris
Win 7 Pro 64 bit + IV 2010 Suite
ASUS X79 Deluxe
Intel i7 3820 4.4 O/C
64 Gig ADATA RAM
Nvidia Quadro M5000 8 Gig
3d Connexion Space Navigator
Message 3 of 8
89198826955
Message 4 of 8
89198826955
Message 5 of 8
cadman777
The error message sounds like you may have to separate the flatpattern to a separate file.
That's just a guess, but it may get you where you want to go until someone else has a better way to do it based on knowledge of the Nesting app.
Here's the Help on Nesting in case you need that level of guidance.
You can separate your individual part by:
1. Using 'MakePart' on the 'Manage' tab if your original part is a multi-body part.
2. Deriving the original part into a sheetmetal part and Suppress the parts that you don't need.
3. Following these Nesting instructions.
Also, you may have to share your part in here so someone who does Nesting can troubleshoot what may be causing it to not work for you.
... Chris
ASUS X79 Deluxe
64 Gig ADATA RAM
Message 6 of 8
89198826955
Detail attached to first post.
I made a separate detail first
I made a DWG and placed it in nesting, the error remained
Message 7 of 8
CCarreiras
Hi!
Why use Unwrap when you can use a normal flat pattern, which is more reliable?
CCarreiras
Message 8 of 8
89198826955
Thanks this solution helped
