Can't figure out how to use Draft tool
Smiley HappyHey guys!
I'm supposed to make a technical drawing from this electronic throttle switch lid but im having trouble making the 3d model first. I can't "connect" the base with the top of the lid. I tried using the Draft tool but it didn't work out as expected.
Obs: English is not my first language, I'm sorry if it is somewhat hard to undestand what I mean. I hope the pictures help you understand what I'm meaning and I hope someone can help me 🙂
mcgyvr
Your English is excellent... I understood you very clearly..
You want to use "Loft" not draft..
https://knowledge.autodesk.com/support/inventor-lt/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/I...
johnsonshiue
Hi! Another option you could consider is using Ruled Surface. If you could not figure out, please feel free to share the part here or send it to me directly ([email protected]). This should be highly doable.
Many thanks!
Software Test Engineer
I think I got it! If I run into any problems, I'll let you know! The Loft tool did the job.
