Can't delete block
Can't delete block
When in part design, I can't delete a block because it says the part contains one or more of its istances.
I tryed to delete one by one all the features of part to find if there were some hidden relations I can't find, but even when I deleted all the features (I have an empty tree) it is not possible to delete the block.
See following screenshot I took.
The block initially contained some sketch objects, at the end I also tryed to delete all the objects to have an empty block (it remains only the reference point).
I really can't figure out how to solve.
bradeneuropeArthur
Read this:
https://forums.autodesk.com/t5/inventor-forum/inventor-sketch-block-will-not-delete/td-p/9511223
Corrupted File!
Arthur Knoors
Autodesk Affiliations:
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
bradeneuropeArthur
This will solve with some i-logic code:
Dim a As PartDocument = ThisDoc.Document
MsgBox(a.ComponentDefinition.Sketches.Count)
a.ComponentDefinition.Sketches.Item(1).Delete
Arthur Knoors
bradeneuropeArthur
Better first to check the sketch for no Name ""
For Each s As Sketch In a.ComponentDefinition.Sketches
	If s.Name = "" Then
	s.Delete
	Next
Arthur Knoors
Thank you, this fixed the issue.
I added a line in iLogic to double check and it found there was an unnamed sketch.
This was not visible in the feature tree and I wasn't able to rename it to take a look at what it contained, but removing it had allowed to delete the undesired block.
I suggest to correct also the thread you linked above (Read this: https://forums.autodesk.com/t5/inventor-forum/inventor-sketch-block-will-not-delete/td-p/9511223 Corrupted File!) on this same topic because "ditch the file" it is not a good solution, no one wants to "ditch" hours and hours spent on a file.
Many thanks!
Mooser91
Hello @bradeneuropeArthur
thank you very much for your ilogic code. I tried it in my .ipt and it worked fine. But one block still remains.
If i try to delete  the empty block, the error message appears.
And there are also some unused parameters, that cant be deleted.
Do you have any idea to "repair" that file, that i have attached?
Thank you very much!
johnsonshiue
Hi! The ipt file is corrupted. There is a hidden sketch consuming the sketch block. As a result, the block cannot be deleted. If you copy and paste the block to another part, the sketch block can be deleted easily.
Many thanks!
Software Test Engineer
