Opening an Inventor drawing file in AutoCAD
almuhandiswep
almuhandiswep
When I open a drawing file (DWG) from Inventor, in AutoCAD, the projections appear as in the attached image. Why?
And another question, even the projections that open in AutoCAD, I cannot modify them, even though I exported the file in Inventor in DWG format.
Thanks in advance.
arron.craig
Where they "raster" views in Inventor when you exported?
A.Acheson
@almuhandiswep what you have is an inventor dwg. It can be opened in Autocad but has limited functionality in that view blocks cannot be changed or exploded and allows adding annotations. If you want an Autocad dwg you need to export as Autocad dwg allowing you to explode view blocks and has all Autocad functionality. See link to export to autocad template. You can also save as see link here
Regards
Alan
Gabriel_Watson
Inventor DWGs are not native to AutoCAD, and therefore cannot be simply modified as usual there. The interoperability is great for making titleblocks in AutoCAD and using them in Inventor, but I would suggest you to stay far away from editing Inventor DWGs in AutoCAD as if you could go back and forth. Usually such workflows are destructive to the drawing and only used for deliverables (after release) when you need to submit some changes to specific customers, and the modified drawing in AutoCAD will never see the light of Inventor again.
A little more on Inv. DWG editing in AutoCAD: https://www.cadlinecommunity.co.uk/hc/en-us/articles/201768852-Inventor-Drawings-DWG-v-IDW-AutoCAD
I would guess that your shaded views may have texture from certain Bitmaps attached... try maybe changing this setting from Always to Offline only?
almuhandiswep
Thanks.
Excuse me
What is the difference - in a simplified form - between raster and precise?
CCarreiras
Hi!
Raster is kind of a "midway" to achieve a view quickly, so, is only partially processed.
Precise is when you have the complete processed view.
CCarreiras
johnsonshiue
Please see my reply to the duplicate thread.
https://forums.autodesk.com/t5/inventor-forum/opening-an-inventor-drawing-file-in-autocad/td-p/11274...
Many thanks!
Software Test Engineer
