Hi, i have a problem with my 2d sketch. I can`t choose "dimensions". why is that?
Solved by bradeneuropeArthur. Go to Solution.
Interesting behavior? What release of Inventor you are using? Any specific workflow you are doing here? These details will be helpful for us to have further investigation.
There is another command active!
In the Statusbar text is shown "Select Center Of Circle"
Press "Esc" to cancel
Arthur Knoors
Autodesk Affiliations:
Autodesk Software:Inventor Professional 2024 | Vault Professional 2022 | Autocad Mechanical 2022
Programming Examples:Drawing List!|Toggle Drawing Sheet!|Workplane Resize!|Drawing View Locker!|Multi Sheet to Mono Sheet!|Drawing Weld Symbols!|Drawing View Label Align!|Open From Balloon!|Model State Lock!
Posts and Ideas:Dimension Component!|Partlist Export!|Derive I-properties!|Vault Prompts Via API!|Vault Handbook/Manual!|Drawing Toggle Sheets!|Vault Defer Update!
