i7 7700hq
ram 16gb ddr5
Nvidia GTX 1050
thanks
kelly.young has edited your subject line for clarity: can this pc run cad2018
What is "cad2018"? If you're asking about Autodesk Inventor, then @rkmcswain gave you a good basic answer, but it depends what you're using it for.
If you're asking about something else, you're in the wrong forum.
Sam B
Inventor Professional 2018.2.3
Windows 7 SP1
My brother asked me to buy him a laptop under 80,000 INR which could run
it(he designs highways by the way)
So can it give him a decent work environment. Thanks man
@Anonymous
But what application is your brother using to design highways? Civil3D, Inventor or something else? Each application and yearly versions has its own system requirements.
Mark Lancaster
& Autodesk Services MarketPlace Provider
@Anonymous wrote:
...(he designs highways by the way)
So, definitely not Inventor! @rkmcswain, can you give advice for someone designing highways?
Sam B
Windows 7 SP1
Civil3D (https://knowledge.autodesk.com/support/autocad-civil-3d/learn-explore/caas/sfdcarticles/sfdcarticles...) would most likely be the application.
Mark Lancaster
I can give you an example of what we run as a typical box for Civil 3D.
i7-7700k @ 4.2GHz
32GB RAM
Intel P3600 series SSD (a bit of overkill, you can get away with something like a Samsung MZVLW512)
NVIDIA P1000 graphics card.
