Hello.
I have noticed that thickness inserted as parameter in text is not correct if it corresponds to flattened sheet.
It also happens to all parameters of flattened sheets.
Hi! The behavior does not look right to me. Please share the files here. Forum experts can help take a look.
Many thanks!
Hi! Please share the files here. I would like to understand why the parameter is not displayed properly in the drawing.
Many thanks!
It does the same for me. As a workaround, why not use the parameters from the folded part? That is, instead of the source set to "test:FlatPattern" (don't know the Polish equivalent), set it to "test" (or whatever the name of your file is).
Sam B
Inventor Pro 2022.1 | Windows 10 Home 20H2
LinkedIn
Hi Folks,
This is a great catch. It is absolutely a bug. It should just work. It looks like the regression happens in 2022. It used to work. I am working with the project team and see what we can do.
Many thanks!
Issue tracked as INVGEN-55968 & INVGEN-54951
