Inventor Forum
Bug report - Sheet metal thickness on drawing not showing correctly
8 REPLIES 8
Message 1 of 9
pbogucki
773 Views, 8 Replies
Hello.
I have noticed that thickness inserted as parameter in text is not correct if it corresponds to flattened sheet.
It also happens to all parameters of flattened sheets.
Labels (3)
8 REPLIES 8
Message 2 of 9
ramsuhas7
in reply to: pbogucki
It is showing to me
Message 3 of 9
johnsonshiue
Hi! The behavior does not look right to me. Please share the files here. Forum experts can help take a look.
Many thanks!
Software Test Engineer
Message 4 of 9
pbogucki
in reply to: ramsuhas7
It is showing in editor, but as soon as you accept and close window it changes to this \X0;
Message 5 of 9
johnsonshiue
Hi! Please share the files here. I would like to understand why the parameter is not displayed properly in the drawing.
Many thanks!
Message 6 of 9
pbogucki
in reply to: johnsonshiue
Hi. Example files are in attachements of this post.
Message 7 of 9
SBix26
It does the same for me.  As a workaround, why not use the parameters from the folded part?  That is, instead of the source set to "test:FlatPattern" (don't know the Polish equivalent), set it to "test" (or whatever the name of your file is).
Sam B
Inventor Pro 2022.1 | Windows 10 Home 20H2
LinkedIn
Message 8 of 9
johnsonshiue
Hi Folks,
This is a great catch. It is absolutely a bug. It should just work. It looks like the regression happens in 2022. It used to work. I am working with the project team and see what we can do.
Many thanks!
Message 9 of 9
liqinomickey
Issue tracked as INVGEN-55968 & INVGEN-54951
Mickey Li
Product Manager
ACS Docs Platform feature team
