BUG - Inventor Causing a Cyclical Dependency by Consuming Sketch
andrewdroth
Advisor Advisor
Message 1 of 74
andrewdroth
By changing a Contour Flange input to a linked parameter it causes the feature to consume the defining sketch without sharing. This causes a cyclical dependency and corrupts the browser.
I had this happen on another sheet metal master part, but I didn't notice right away and it wasn't until I tried to move the EOP marker that I found out about the cyclical dependency, and even then it wasn't clear what cause it. I ended up losing a lot of work by needing to start over on the features below the problem.
Please fix!
Andrew Roth
rothmech.com
YouTube IconLinkedIn Icon
IV2025 Pro
Apple IIe Workstation
65C02 1.023 MHz, 64 KB RAM
Apple DOS 3.3
Replies (73)
Message 61 of 74
Message 62 of 74
jletcher
 That explains when you want to share with features not another sketch and this is what I am trying to explain to you.
 It is a bug just not the bug you think it is.
Only way you will get it to work is wait a few months to see if they can make it work or put your contour flange between sketches 16 and 17.
 Those are your options.
You may hate me but you know I am 100% correct.
Wish you all a good Thanksgiving.
Message 63 of 74
andrewdroth
Sorry bud, you're 0% correct.
I fixed this a few minutes before posting the bug. I was simply exposing the bug, not trying to get it to work.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 64 of 74
jletcher
 No part for me to test?
No video to prove?
Have a good Thanksgiving.
Message 65 of 74
andrewdroth
Here you go fella.
Thanksgiving was 6 weeks ago...
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 66 of 74
jletcher
 Try again, you must not have edit the feature again, and that is what creates your issue.
Message 67 of 74
andrewdroth
I don't need to edit it. It's good. It's what I want.
If you can show me any other type of feature consuming a shared sketch I'll mark your first reply as the answer.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 68 of 74
jletcher
 So you rather have issues then put the feature where it needs to be?
 Don't let your hate for me corrupt your file.
Message 69 of 74
andrewdroth
It's not corrupt. As long as I don't edit that feature (which I don't need to) it works as it should.
Worry not, I'm not changing anything on account of your input.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 70 of 74
jletcher
@andrewdroth
"Worry not, I'm not changing anything on account of your input."
 You can learn a lot from my input.
I will leave you to your hate.
Message 71 of 74
Message 72 of 74
Xun.Zhang
Hello Guys!
I am not aware of this thread could be HOT like this!!!
Here is a quick update from Development team which indicated this one is indeed a problem and able to fix in short.
The problem is with browser collectors and sketch consumption, the first call removes the shared flag, so the second one thinks the sketch was not shared (even if it was), so it moves the browser node right before the feature. Which is the problem here, that's why the feature consumer is complaining about sketch being moved.
Sorry for the inconvenience here, and a quick call - can either of you tell me how urgent of the fix to deliver? In other words, are you expect to fix it within 2019 updates?
Hope it helps!
Xun
Message 73 of 74
andrewdroth
Hey @Xun.Zhang,
Since it is causing parts to become corrupt I would say it's worth adding to the 2019 fixes.
Andrew Roth
rothmech.com
IV2025 Pro
Apple DOS 3.3
Message 74 of 74
Who all is feeling Kurupt this morning!?  Have a good holiday, everybody!   Best wishes to everyone.
