Issues with rendering glass.
Test Image -002.pngI'm trying to create photo realistic images and having some issues with the rendering of glass panels.
Note the swirl on the glass.
I have tried altering the reflectivity, translucence, transparency, shadowing and render method with no luck.
I'm only using a trial version.
Any suggestions?
johnsonshiue
Hi! This could be related to the lighting styles. What lighting style are you using? Could you try using a different lighting style?
Many thanks!
Software Test Engineer
Currently using one light. Have tried moving the position to reduce shadowing and adjusted the light colour. Tried 2 lights, no difference.
Will keep on trying other settings but its a funny one because the views are perfect before I launch the render environment or use ray trace.
Thanks anyway for the suggestion.
dgorsman
Just a question - is that actually glass *through* glass i.e. the doors?  I suspect there may be an interaction between multiple transparent materials resulting in a moire pattern in the render.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
