BOM Base qty value does not match Parameter value
timothy_berg
Message 1 of 9
timothy_berg
Hello, I'm having trouble with the value in the base qty of the BOM. This only happens when i make a custom parameter and set it to the base qty. The value in the parameter list is correct the value in the Base Qty drop down is not. The only way I've been able to fix it is to add another custom parameter and reset the Base Qty to the new parameter. Hopefully this makes sense please see the attached screenshots.
Replies (8)
Message 2 of 9
johnsonshiue
Hi Timothy,
The behavior does not look right to me. Please share the files here or send them to me directly (johnson.shiue@autodesk.com). I would like to see why the G_L is not properly updated.
Many thanks!
Software Test Engineer
Message 3 of 9
johnsonshiue
Hi Tim,
Like I replied to you in the email, the issue is related to the suppressed derived node in the mirrored frame member. The G_L parameter from the source cannot be propagated to the derived mirrored member because the link is suppressed. If you unsuppress the link, the values should be in sync.
Many thanks!
Message 4 of 9
lena.talkhina
Hello @timothy_berg  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
Message 5 of 9
timothy_berg
I did not find a solution for this issue and I've attached another example of the value in the Base Quantity field not matching the value in the parameter field.
Message 6 of 9
lena.talkhina
@timothy_berg thank you for coming back to our forums and let us know that you still facing the issue.
Sometimes it's not easy to find the right answer.
I hope other users and our colleagues will help you soon.
Message 7 of 9
johnsonshiue
Hi Timothy,
The attached part does not seem to be the same as the one in the image. Could you share the part you have?
I also notice another issue with LENGTH ISSUE.ipt. There is a unitless parameter called SQINCH but its value is set to 1in. This is wrong. It can lead to BOM errors.
There is a workflow to make area as BOM quantity. If you want to know how, I can show you.
Many thanks!
Message 8 of 9
timothy_berg
Johnson,
Sorry about that I must of loaded the part before saving, please check out the part in this post. Please disregard the SQINCH parameter.
Message 9 of 9
johnsonshiue
Hi Timothy,
It does look like a bug to me. I need to work with the project to understand it better. Something is wrong with the workflow.
In the meantime, the workaround is to create a User Parameter and have it linked to the Model Parameter dictating the length. Then use the parameter (or the Model Parameter) as the Base QTY.
Many thanks!
