Sketched linetype scale - still not implemented?
thenottakenname
thenottakenname
Hello all,
is there still no way to change the linetype scale on a sketched line in an .idw? I have an assembly that will butt up against a pipe, and I've sketched in a circle with hidden lines to represent it - but the dashes are so small that it appears solid when printed, even on 11x17. Same thing occurs with chain lines, which I use to put a border around "shipped loose" items. Ideally don't want to convert for use in AutoCAD, or create a part that when viewed from above, looks like hidden/chain lines aha.
Aaron Wilson
Inventor Professional 2022
AutoCAD 2020
thenottakenname
Hey, so, uh, there's this little checkbox in the layer section of the styles editor that I always glossed over called "Scale by Line Weight", and when that's unchecked, the lines appear properly. Just for anyone else that has that issue -- my searches only brought up threads from 4+ years ago saying it couldn't be done.
Aaron Wilson
AutoCAD 2020
