Creating a Rib Question
PCAPUTO85
Message 1 of 17
PCAPUTO85
I am trying to create a rib part I am working and I am having diffuctly creating a rib or feature that is flush with a domed surface.
Replies (16)
Message 2 of 17
JDMather
zip (not rar) your *.ipt file and Attach it here.
Message 3 of 17
TheCADWhisperer
Going out to the very edge of the base cylinder would not make logical sense since the edge is circular while the top of the rib is planar and the bottom edge of the rib is a line, not an arc.  And at the intersection with the spherical surface it would not make logical sense for it to be a line.
Once you have Attached your attempt - I can post my solution.
Message 4 of 17
IgorMir
Here is a quick version of it. But I wasn't using Rib tool for it. In this particular model it seems not working. Frankly - Rib tool has a mind of his own from the day it was conceived. Hence - the old fashion technique comes to the rescue every now and than. The attached file is in IV2020 format.
Cheers,
Igor.
Web: www.meqc.com.au
Message 5 of 17
PCAPUTO85
I attached the file for you to look at.
Message 6 of 17
PCAPUTO85
Thank you
Message 7 of 17
PCAPUTO85
Here is my file
Message 8 of 17
TheCADWhisperer
Your sketches are not fully defined (especially Sketch1) and you have extraneous dimensions that are not on the original drawing (see Attached file).
Message 9 of 17
PCAPUTO85
The drawing was missing some of the dimensions, that why some were filled in. I am still not understanding how you go the rib feature to be flush with the domed surface when I extrude it, it goes straight out, while on your it curves around.
Thanks you all your help
Message 10 of 17
JDMather
@PCAPUTO85 wrote:
The drawing was missing some of the dimensions...
The drawing was poorly done, but no missing dimensions.
You should be able to drag the red End of Part marker up to the top of the history tree and then drag it down step-by-step to reproduce the steps.
Can you ask your instructor to join this discussion?
Message 11 of 17
PCAPUTO85
The drawing is from am old mechanical drawing textbook. Sorry for the confusion, but I am the instructor. I teach high schoolers and I am learning the program myself. I will take a look again. Thank again for your help.
Message 12 of 17
JDMather
I have been teaching for more than 25 years, so I recognized the problem.
One thing about these old textbook problems that preceded 3D CAD is that the images were done by hand on drawing board and liberties are taken with the hand-drawn geometry that is not physically possible in the real world.
If you have trouble following the steps - post back and I will create a video for this problem.
Message 13 of 17
PCAPUTO85
That would be great and most appreciated.
Message 14 of 17
IgorMir
Hi;
Do you think that's the appropriate representation of the rib?
Cheers,
Igor.
Message 15 of 17
TheCADWhisperer
Drag the EOP to the end and capture the same two images.
Message 16 of 17
IgorMir
Thanks, my bad. I was indeed looking at the rib itself and got the EOP up. But than again - the upper surface of the rib is rounded now. It is hard to tell if it is a design intent or not. But since it is just an exercise - it might do.
Cheers,
Igor.
Message 17 of 17
TheCADWhisperer
If modeled flat - other assumptions have to be made.
