Inventor Forum
Bolted Connection on Point
3 REPLIES 3
B_Bevelander
1354 Views, 3 Replies
I can't seem to get Bolted Connection to work with the on point selection in my Assembly and the Tutorial provide doesnt cover this.
I tried to create a point sketc at part and sub-assembly level but neither get detected by the BC feature.
Any explanation would be greatly appriciated.
3 REPLIES 3
CCarreiras
in reply to: B_Bevelander
Hi!
Creating a hole:
To place a hole based in a sketch point, you use the  "BY SKETCH" option,
"On point" Refers to a "WORK POINT", not a sketch point.
Creating a bolt connection.
In The same way as the holes, the ON POINT option refers to a work point, not as sketch point.and (you dont even have that "by sketch" option in Bolt Connection).
How to do it:
Just create a work point in your assembly (or part or subassembly), and select it to be the center of your BC.
CCarreiras
srionde
i am working with skeletik method.
I am creating a main Skecth file with proper configuration about frame, and holes to do.
When i put this sketch fil on a welding assembly, so i can use the skecth point with the bolted connection to insert my screws.
Only problem with it:
 as my sketch is used for severals assemblies, the holes select every point from the sketch includings the points that are not used with a specific assembly.
see the print screen, there is 2 differents conveyors there, with points on sketches for the hole i need and supporting frames
kelly.young
in reply to: srionde
@srionde sounds like there are many points so not sure if this helps, but if you hold down Ctrl you should be able to deselect the points you don't want.
